65 Coupe Wiring Harness
My Brothers and I built a 65 Coupe Kit and put a LS3 GM Crate Engine in it and we love it. There is no other car like it after we had it tuned on a Dyno!
What I would like to know is if you have changed the Wiring Harness on this Kit. It was too hard to work with because of the Connectors used. Once connected it was damn near inpossible to disconnect them. Plus there was a wire or two missing in the harness.
May I suggest a connector I have used in the past? Molex makes a dandy connector that would work well in this application and they can be easily connected and disconnected.
It addition I would suggest that a more robust Toggle Switch be used.
I went with an I-Squared system. Their new version looks pretty cool
