0
0
Fuel Lines started Coupe with 302 and MSD Atomic EFI
Anyone running an MSD Atomic EFI system? I am. I have not found much info on this and that forum, so I will post stuff as I make my way thru it. Anyway, the Atomic system comes with fuel pump and filters, these are 3/8-inch. But the Complete Kit tank and fittings are 5/16. . . so I got some adapters from Summit.
Anyway - today I started to mock up where to mount the external fuel pump and how to run the lines. Didn't get too far, I need to figure out what and how to do this. Here are some pictures of my fuel pump mounting plate.
Other than making sure nothing will hit or crunch the filters, pump and lines - are there any other precautions or hints that I should be aware of? The flex fuel line will run along the passenger side chassis rail, like most builders have been doing. The second filter will mount near the passenger seat area, but have not decided on the final location.
More details on my WordPress site:
http://wayneyoshida-kh6wz.com/2013/1...system-begins/
