0
0
33 Hotrod Coyote Air Conditioning
Has anyone built a 33 with a Coyote engine, and installed air conditioning? If so, did the compressor mount in the stock location, lower right side of the block, or did you have to use an aftermarket accessory drive kit? If you used the stock mounting point, is there any trick to making the idler work? Thanks.
