Shift Rod Arm for use with Very Cool Parts K-tuned shifter assembly. Provides additional clearance at the rear of the vehicle where many people are reporting that the stock hardware is hitting the bodywork. Optional cable bracket is not required, but it corrects the geometry so that the cable is mounted in parallel with the shift rod for the most efficient operation.
SOLD OUT
This is how much space is saved over the stock hardware (approx. 40mm):
This is how the FFR supplied bracket is modified after cutting it down for the K-tuned shifter cables and moving it forward for the aluminum shift arm:
This is the bracket that I came up with:
Mounted with the supplied bracket from Waynes K-tuned kit:
