Results 1 to 25 of 25
Thread: Turbo Heatshield, Zero Decibel Motorsports
Threaded View
    Mechie3's Avatar
    Zero Decibel Motorsports Turbo Heatshield
    What:
    Stainless steel heat shield to sit over the stock WRX turbo.
    Why:
    The turbo sits extremely close to the rear suspension brace. A couple heat shields made for Subaru applications didn't fit due to the close vertical quarters. The Zero dB heatshield bolts directly to the suspension brace and wraps down the sides of the turbo to reduce heat soak of the intercooler that sits above the turbo.
    Cost:
    $58
    Shipping
    Shipping will be quoted on a per case basis to keep costs down and ensure you only pay actual shipping charges.
    Includes
    Laser cut stainless steel heat shield
    Laser cut mounting bracket with laser etched logo
    Stainless screws, washers, and nuts for mounting
    Coated rivnuts
    Expected part availability: ~Mid November
    FAQ
    Does this fit any turbos besides the stock TD04?
    It's likely, but hasn't been tested. If you have a non stock turbo and want to try this out there is a discount available for the first person to try it on a specific turbo. All I ask is you perform a timely test fit and send me photos
    Does it fit over a turbo blanket?
    One member (CPlavan) has fitted one to his 818R with a turbo blanket. See below for photos.
    How do I install the heatshield?
    See below for photos. Slide the heatshield over the turbo with the suspension brace installed making sure it clears the wastegate arm. Attach the bracket and hold the heatshield assembly where you want it. Mark the location of the front and rear mounting hole on the brace. Remove the bracket, drill, and install rivnuts. Replace the bracket and insert screws into the two new rivnuts. Ensure all screws are tight.
    How do I order?
    Send me a pm, email ([email protected]), or message me on facebook.
    Pictures:
    Note: Prototypes used an aluminum bracket. Production versions will have a stainless bracket.
