Which e-brake cable do I need.
I am working on a 33 Hot Rod for a friend. It has the Ford 8.8 3 Link rear end. I am using the Willwood MY 120 10112 RD rear calipers. My problem is I don't know which e-brake cable to use. I called FFR and they said I need to call Willwood.
Which is what I did. Willwood stated that I needed their cable part #330-11282. When I looked at a picture of this cable I could see that it was the wrong one. It calls for using a balance bar to hook the cables to the e-brake handle, plus the cable only sticks out about 3 inches from the rubber housing. The bracket on the frame to attach the cable housing is 2 feet away from the handle.
Has anyone out there had this problem and if so how did you overcome it.
Any and all help is very much appreciated, Thanks Larry
Post Thanks / Like - 1 Thanks, 2 Likes
