Thought I would throw this out there if anyone else has a problem with the FFR supplied fuel pump bracket and tank seal.
I had a frustrating time trying to seal the pump line. Wouldn't seal with the white FFR quick disconnects, wouldn't seal with 5/16 line clamped directly on it, wouldn't seal with a smaller size 1/4 in line clamped directly to the line.
Turns out there was one or two pinholes in the ridge that is meant to hold the quick disconnect onto the fuel pump line.
I cut the tube off just upstream of the ridge, and replaced the 5/16 fuel line clamped directly to the fuel pump line. No Leaks now.
Hope no one else has this problem, its a quick fix once you find the leaks...... but now my garage smells like gas.
