My Hot Rod has a Coyote engine which requires the use of the Ford Power Distribution Module; I am planning on mounting this PDM under the dash behind the Vintage Air A/C evaporator;(with an aluminum base plate, etc.) this could present a problem down the road if there is a fault in one of these circuits, since the PDM will be up under the dash I won't be able to see the LED indicators or change a defective fuse that may be needed for trouble shooting. I was thinking of mounting some kind of retractable base that would allow the PDM to be dropped down from under the dash, then pushed back up again when finished and latched in position up under the dash until the next time it is needed.
My question is do any of you know where I can acquire such a mechanism?
Or how have you mounted the PDM and how do you plan to access it during trouble shooting events?
thanks in advance,
Nevin
