Thanks Thanks:  7
Likes Likes:  3
Results 1 to 40 of 134
Thread: Post Your Weights
Threaded View
  1. #10
    Bowling Green, KY
    Not sure I can get there Tony being 190lb's but believe me I am doing all I can to save a few ounces here and there, I have even lost 20lb.
    I believe the R chassis is a bit heavier but we don't use the door hardware, the doors are bolted to the side sail and rocker. Like Tony I am running a 15 gallon cell (mine is in the passengers seat area) a JDM header is 15lb lighter than the cast iron OE exhaust, small 10"X3" muffler, all tube rear links, AP brakes and hats (almost -40lb from OE brakes) 3.5lb battery, Iwire harness, rear firewall and fuel cell firewall is 15lb lighter than FFR's, Steering shaft 10+lb lighter than OE, Wilwood pedal box is a lot lighter than OE, 9lb flywheel, mounts, tabs and brackets are aluminum or thin wall 4130, no e-brake mechanism or cables and I am running one 10" fan are a few things I have done.
    I am getting the car back together and will have back on the scales in the next week, Had on the scales a few weeks ago with the rear fascia and hood off the car, I believe I will be little lighter than Tony when all back together. Now I am excited to get it back on the scales.
