0
0
couple of quick build questions
I'm slowly progressing on my 818s build. Couple of questions. First, I've disassembled both axles and am about to reassemble with the FFR supplied axle. Inner boots were toast and when removing them all the grease flowed out. No problem as my new boot kits came with grease packets. On the rear outer hubs, the grease stayed inside with the bearing hub. Should I just reuse the grease or try and clean it out and use new? Seems difficult to get it out without damaging the ball bearing socket. Hope this makes sense.
Secondly, the brackets for my rear sway bar (06 WRX) do not mount flat to the frame. I bent them a bit, and I want to verify that bending the tabs where the bolts go through is the correct way to make them fit.
Build is going well, even though I've caught a bunch of mistakes that I have had to redo. Should be picking up my rebuilt engine in a week, so I want to get the front suspension buttoned down and the axles ready.
