0
0
Inertia Switch
Finally have the engine and drive train installed. At start-up, the electric fuel pump would not work. I pulled the inertia switch and and connected a wire between the two main switch wires and the fuel pump worked and the engine started and ran great.
I went to the Ford dealer and bought a new inertia switch, and to my dismay, once plugged in, it also does not work. Several attempts of hitting it and resetting it did not work. On the entire build, the electrical is the most challenging for me. Does anyone have a thought? Is there a simple way to test the switch? I can't believe that both switches are bad -- but who knows. Thanks
