With help from my Dad, we flipped the body over and put it back on the car. Every time we try to put the body back on, it seems as if it's not going to fit. Then after a few minutes of struggling, it pops right into place. This time I was more nervous putting it back on since I added all the trunk aluminum, dynamat etc. I figured this time it wouldn't fit, but I was wrong. The usual few minutes of struggle, then magically it's on.
I finally can see how those "wings" on the side trunk aluminum pieces will fit in. I always assumed they were meant to sit to the frame, but see now they will fit against the body and I'll tie them in later to seal between the inside and the outside.
There's a little bit of a gap between the front mount and the body that I'll have to shim up.
The back mount is just about touching
Zoomed out it looks pretty good
Little bit of a gap on the driver's side between the door sill and the frame
The passenger's side has a slightly bigger gap
-Matt
