Results 1 to 20 of 20
Thread: Speedhut Speedometer MPH - Thoughts?
Threaded View
    mburger's Avatar
    Punta Gorda FL
    Hi folks.
    I am looking at ordering the Speedhut Cobra GPS gauge set to replace the stock 1990 donor gauges in my MkII. I missed the Christmas sale, and the next sale in the Spring will only be 5% - 10% off. With the standard 180mph speedometer gauge, I would only use the first 33% of the gauge. 90mph is at the 12 o'clock position on the 180 gauge. I was thinking of substituting in the 140mph speedo instead. My thought was it will give me a more realistic usable sweep. Do most of you folks use the 180mph gauge? What are your thoughts? I plan on swapping the tach and speedometer positions and also plan on removing the oil temp gauge from the kit. Main reason for that is I won't have to cut a new opening and possibly need a dash re-cover. My existing dash holes are correct for these gauges as well. (I haven't figured out how to rotate the dash pic. It looks ok on my PC. Sorry about that)
    Mark
    Mark
