0
0
Oil Temp sensor, GPS
Hell All. I have 2 questions - hoping to get some advice from this great forum.
Roadster complete kit 347 stroker engine with EFI.
My oil pain does not have an outlet for the oil temp sensor. Oil pressure fine as I bought the angled fitting from Breeze. I did use the FF oil relocation kit and I did see that some guys use that to mount the oil temp sensor.
Has anyone done this and if so what parts did you use? I have seen everything from removing the oil pan and having a bung welded to replacing the drain plug with the sensor. I would rather not go that route if I can mount it to the relocation kit - nice and clean. Also,
I have the vintage guages from FF and want to use the GPS speedo. How is this mounted and connected?
Any help on the above would be appreciated.
