Not sure if others have run into this before and not sure what to do about it. started the body work on the hard top, the base that sits on the body is uneven on the drivers side back behind the door. The inside shell is 1/8" higher than the outside shell, this will leave the gap between the hardtop and body. The passenger side is even inside and out. I think I should build up the low area so that inside and out are enen?
