0
0
The “pyramid” adapter I have will only fit on one way. It is not triangular. My steering wheel is out about 90 degrees with the rack cantered. I’ll have to off center the rack a bit, and play with the tie rods to get it centered. Life would be much easier with a uniformly drilled steering wheel. I am not sure of the rationale behind the current unsymmetrical hole pattern.
