0
Front tires rubbing when turning
I am using a 07 wagon donor but replaced the LCAs with aluminum. The control arms were mounted to the inner holes and the tires rubbed when turning hard. I moved the control arms to the outer holes and no rub but then there is not enough tie rod left to secure them. Any suggestions?
