0
0
Help needed-stupid move
Guys,
I did a dumb *** move-I installed the steering control brackets up side down-the Conical hole is facing the wrong way-ahhhh
Best part, I had the whole front suspension done-then I went to put the steering rack in.....and guess what, installing the conical ball joint from the steering rack would not fit in.
So, I took off the brakes, no biggie, undid the lower A arm ball joint cotter pin and nut, no biggie-thinking I would just slide the steering bracket off and flip it to the correct orientation-wrong!
The bolt are just about 1/2 to long for that to happen-****
So, How do I loosen and get the lower ball joint out of the spindle??????
Is there a tool for that? Trick of the trade.....
Any input and help is much appreciated-
Martin
