dieting advice
Hey guys,
What's a good way to go about this? In my mind, I imagined bundles of wires that had to go from point A, where they did something (sensor, light, etc) to point B where they got controlled (switch, ecu, etc), with maybe a little bit of daisy-chaining and some extra wires for grounds. Clearly, I underestimated this job. I had hoped to separate out cords of wires that went to a similar place, perhaps with a similar purpose, that I could lengthen/shorten/eliminate.
I've armed myself with Craig's ID thread, the FSM, an assortment of tools, and a trash can. But I'm having a heck of a time untangling this mess.
Do I just cut some wires, untangle, lay everything out, and solder back together? Mark the connecter a wire goes to, cut close to the connector, untangle, lay everything out, then get some pins and re-pin it one at a time?
Thanks.
