0
0
Accelerator Pedal
Anyone have any pictures of the stock accelerator pedal set up? When installed, is it normally much lower (level wise) than the brake and clutch pedal? Mine seems to be much lower. I could probably adjust the others lower but I feel like I would not have enough throw on the clutch or brakes. I'd like to try to make it work without buying any more extras (aka Lokar cables, kootenai aluminum footbox, ect)?
Also, it seems like the whole throttle cable is waaay too long. I have a holley carb. I take it that you are supposed to snip the ends off the throttle cable and use the factory 5 supplied ball end pieces? I went ahead and did it (1st picture). What is the little supplied spring for (second picture)?
