0
0
Master cylinder sizing
Sir
During assembly of the peddle box on my gen 3 coupe it came to my attention that the master cylinders bore were different sizes. As per the instructions on page 180 the 3/4 Master cylinder goes into the left mount and the 5/8 master cylinder in the right mount. The picture illustrating this shows the master cylinders one on top of the other not left to right. It would be helpful if the orientation of the picture was the same as the orientation of the text. Question 1. Which master cylinder goes in which slot. On Page 182 where it talks about balance bar adjustment it states the master cylinders are the same size bore. This contradiction in the manual is causing further confusion. I called factory five and was told it doesn't matter which size master cylinder goes in which position. I did not get an explanation as to why it doesn't matter.
Question 2. Please explain the thought process behind the two different size bore master cylinders. And The thought process behind why it now doesn't matter.
Thank you
Bill
