Lizard Skin planning and process
The engineer in me wants to plan stuff out in advance. So, here痴 what i知 thinking for coating the panels. I知 building my 33 with the top and windows so I know I値l have some heat to think about.
- Drill all the panels first
- Scuff the panels
- Tape off (blue painters tape) where the panels will contact the frame.
- Tape off any areas where panels will overlap
- spray both sides of the panels (I expect a couple of coats) if I hang them
- Remove the tape before the lizard skin hardens. How can I do this if I知 going to apply both sound and heat coatings?
- Maybe use the Top Coat on the underside
Any comments or thoughts?
The alternative is to just remove all of the lettering and use as is with the insulation kit and carpet! Certainly a lot easier but I知 not sure if sufficient even here in Michigan.
- Peterh226
35 Hot Rod Truck (Ext) Delivered 11/21/24
33 Hot Rod Gen 2 #1134 ~1400 miles
54 Pontiac Star Chief
05 F-150
