![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
0
0
(Fixed with logic board swap) More ABS challenges - 95 GT 3-channel module (Help!)
So my ABS headache continues. My first ABS module from the salvage yard had 3 of 3 stuck solenoids. It would pass the self-test and the pump will run, but I wasn't comfortable with the idea of heating everything up and smacking it with a hammer.
I had the salvage yard send me a replacement module, which kind of saved me some work because I had cut the first mounting bracket smaller than I wanted it. The new unit clicks all 3 solenoids and the pump spins up, but it on'tt pass the self-test! (YGBSM!)
I commenced heating the stuck solenoid unit with my heat gun and gently smacking it with a hammer and got one of them loose, but the other 2 remain locked. Any tips, tricks, or how to videos on how to break them loose?
So what to do now? Get a 3rd salvage module? Pony up and buy new if I can find one? Can I swap the good electronics portion on the stuck solenoid module over to the functional solenoid one?
I need to finish this so I can mount it, make up new brake hardliners and move on to the entire wiring harness and new engine...
Shack
Reason: Updated with new info.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
