0
Steering Column Issue (Gen 2 Frame)
went to install the steering column. The top bracket went in a little snug, but the bolts slid right in.
Went to install the lower bracket in the top bolts on the frame and they do not line up with the slot in the column.
I'm debating whether it is better to clearance the slot on the column or drill the hole in the frame to fit.
Any advice?
