35
155
Thanks James!!!!
I'm moving on more to the electrical side of things. I'll be pulling all the sensors and coils off the engine so I can solder, pot, and boot to a Deutsch AS connectors. More on that in the other thread. I've started with running the large gauge battery cable to the rear passenger compartment behind the fuel tank. My thought is that I wanted to run the positive to a distribution post here and then run a section to the starter. Also running a ground wire from a distribution post to the exact location the engine is grounded to the frame. I can then pull power and ground from these two spots for the power distribution block that feeds the ECU.
As a note, I'm follow as much star point earthing as possible with this approach.
Do you guys see any issues putting these distro blocks here? They already clear the tank so no issue there.
