Results 1 to 5 of 5
Thread: Tfs 11r on 289 with stock heads?
Threaded View
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    my hope and dream of using worked iron heads on my 289 are out the window.
    The tfs 11r has a similar combustion chamber.
    I see there can be issues with piston clearance.
    Your experience is appreciated, can I do it with stock flat tops with valve reliefs at stock position?
    edit to include cam specs:
    int exh
    valve adjustment .018 .020
    gross valve lift .529 .542
    dur @ .0.0 tappet life 271 279
    valve timing @ .050 open close
    int: 12 BTDC 44 ABDC
    exh: 47 BBDC 15 ATDC
    @106.0 intake centerline
    int exh
    duration @ .050 235.00 242.00
    lobe lift .3310 .3390
    lobe separation 106
    Victor
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
