Requesting assistance with the following questions. As background, I received my 33' kit Feb 2020. I have the most current manual, both print and electronic. I'm doing mock-up fitment and wiring for my headlights/indicators. These are the FFR 33' HR provided LED headlights, and I have zero experience with LED headlight systems so if my questions seem well; dumb my apologies. I'm not considering running DRL unless someone talks me into it to avoid later issues. I'm testing operation of the headlights using a 9V batt without being connected to the FFR/Ron Francis harness as I do not have my headlight switch or 12V system completed. I'm not currently concerned about the indicator and/or parking light operation(s)...yet.
1) The build manual "Headlight Connections" chart indicates the low beam "FFR red" wire connects to the "headlight plug pigtail" green wire. On the provided headlight plug pigtail in my kit there is no "green" wire, but a "white" wire is present, as well as the red and black wire. Is that new to the headlight system, and does the manual need to be updated or do I have the wrong pigtail or does it frankly matter what color it is as long as it works? (see below)
2) When I test the above described white "headlight plug pigtail" which is supposed to be the "low beam" FFR connection to the FFR harness red wire, it illuminates both the top and bottom lights in the headlight assembly. When both LED's are lit is that low beam?
3) When I conduct (pun intended) the same test with the the red "headlight plug pigtail" which is supposed to be the "high beam" FFR connection to the FFR harness brown wire it illuminates only the top half of the headlight. Is that high beam?
Thanks in advance for the assistance!
Whit
