here's the parts I have purchase
Built coyote(317in) in build process
Darton sleeved
custom Manely extreme pistons
Boostline rods
Winberg billet crank
Billet main caps
gt500 oil pump kit with boundry billet gears
Comp custom designed blower cams By Billy Godbold
Ported heads by Tim Eichhorn NPR racing engines
Whipple 3.8 supercharger (New design 2k+hp Completely reengineered not out till may/June 2021)
super 8.8irs with 3.73 Torsen
GForce performance outlaw half shafts
liberty gear built t56 magnum
Browell bell housing
black magic defiant slipper clutch
s197 spindles front
6 piston Brembo (s550) 15" rotors front (2013 gt 500)
4 piston Brembo (camaro/ctsv) on 11.88 (s197) rotors rear
Forgeline GA1R 18" wheels with Toyo r888r tires for road racing
weld wheels 15X12 double bead lock for drag strip and skinnies up front
Girodisc full floating rotors
AEM engine management system
building my own chromoly upper and lower control arms and pushrod/bell crank adjustable spring and damper system
Images below were of my original build that has since then been torn apart to remove Boostline rods to be used in my big power build.
now I have 2 engines one is Edelbrock 2650 supercharged and the other is the big Whipple build.
Reason: edit as I add parts
