![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
0
0
Dead Pedal
So my GTM decided it was going to be a hard start. It almost seemed like the battery was dead or dying with how it started; at first nothing and then a slow crank to life. It never did that before. When it did finally start, I had no pedal. I could put it to the floor and nothing would happen… no increase in RPM’s… nothing.
I shut it off and restarted it. Although it started without a problem, there was still no throttle. I disconnected the negative terminal of the battery for an out 30 seconds and then reconnected it. I had my throttle back!
I just wanted to post this for anyone that might have a similar situation and to see if anyone had any ideas how long I have before the electronic throttle decides to call it quits for good.
![FFMetal](https://thefactoryfiveforum.com/attachment.php?attachmentid=195371&d=1707243047)
