0
Front Suspension Setup
Hey guys, doing a quick mockup on the front suspension. It's a pin drive front setup that uses SN95 spindles with adapters for the top ball joint. Because of this there's not a lot of information on it from FFR, Dave L even looked back in some older manuals when it was a standard option and couldn't find anything. So I'm a bit like a blind man at an orgy, I'm just feeling my way around....
As a start, when in ride position are the lower control arms basically level with the ground? I did some quick measurements and calculations and based on my wheel diameter and aiming for the bottom of the 4" round tube to be 4" off the ground it would appear they should be close to level.
Am I correct?
