0
0
FFR front spindle install question.
After 7 months I finally received my front spindles for my coupe kit and I am having trouble with the install. When I attempt to screw on the castle nut for the upper ball joint, the ball joint just spins with the nut and it doesn't go any further up the threads. The manual say to torque to 75 ft-lbs. I have no idea how will get to that torque spec when the ball joint spins so freely just trying to get the nut on. I am using the Howe racing ball joints instead of the FFR provided ones. Is there a set screw or something that is supposed to be used to hold the ball joint in place while torqueing to spec?
Thanks in advance.
V/R
Shakey
