0
Hydraulic Reservoir options
Like others here, I've decided I want separate reservoirs for front/rear brakes and clutch master cylinders. There are numerous options out there. My question is, how much does the capacity matter, if at all. Some are as little as 1oz per reservoir, others are more in the 3-8oz range. For example, on a track day when the brakes are getting used hard, does a larger reservoir do anything to help keep lower fluid temps?
