0
Hotrod windshield frame not sitting flat on the body
I'm in the process of mounting the cast windshield frame to the body and as you can see in my pics, there is a 1/2" gap between them in the middle. Is this typical? Has anyone else run into this before? I can't believe the body will flex that much in order to seal up against the bottom of the windshield when I tighten the nuts. Do I need to fill the gap in with fiberglass and contour it or do I need to shave the far edges of the windshield frame down in order for the middle to sit flush?IMG_20241021_184637904.jpgIMG_20241021_185044601.jpgIMG_20241021_184529532.jpgIMG_20241021_184522748.jpg
