0
Dash Cowl Clearance question
I have been pouring over pictures of my last build but I am wondering if someone has anything definitive. I want (need?) to know how far below the edge of the dash or frame the dash cowl hangs off the body. With my current layout my closest gauge measures 27mm from the top edge. Once I lay on the body how much of that will the edge cover up? Will my gauges as laid out now clear the body cleanly. With 5 inch Tach/Speedo I am using a lot of real estate. I am just looking for something general. I am not ready to test fit the body nor have I decided how I am going to attach my dash. I do have it test fit like my last one where it is sitting just below the corners of the frame as can be seen below.
I appreciate your input.
