(Mk IV roadster; IRS; 11.65" rear disc, etc.)
Okay, here's a specific idea to "quantify" the process for setting the two master cylinders (front/rear) bias.
Use a hand-held IR pyrometer. Drive at say 50mph, brake with medium effort perhaps three times, then quickly record the temperatures of the front vs. rear discs.
Do this a couple of times and consider the temperature delta. Maybe repeat with higher-effort braking (allowing some driving in between for a little disc cooling).
Maybe the experience with this (temp data) from the forum, will help to "quantify" what otherwise is a very subjective effort of trying to "just lock the fronts before the rears lock" or other techniques.
Ideas...?
