0
0
clutch problem.
Ready for first go cart drive of my type 65 coupe but need some help with a clutch problem. Have a new coyote and 6 spd. tremac. Wildwood hydraulic clutch. Everything is new. I believe I have the clutch adjusted correctly about 1/8 in free play before the throw out bearing contacts. Here is the problem, On blocks with engine running I can step on the clutch and engage 1st gear or reverse or go through the gears. Wheels are still before I engage then spin normally. On the ground engine running stepping on the clutch I cannot engage 1st gear. Trying to engage the car ties to move forward. I believe I may need a larger clutch master and slave cylinders. I have a 3/4 in master and the slave moves about 1 in fully depressed. Any thoughts or advice would help. Thanks in advance.
