Results 1 to 40 of 114
Thread: If it were easy everyone would do it?
Threaded View
  1. #11
    Senior Member sk7500's Avatar
    Rear window #2
    As most of you know I did a Polycarbonate rear window. We'll I have had it in for about a year now and have had no problems at all with heat or scratches. The one problem I did have was my insufficient preperation of the surface I back painted black. I used a PC that is hard faced on both side for scratch resistance and UV protection. So sanding it was most difficult and I apparently did not do a good enough job because when I glued it in I developed air bubbles where the paint pulled from the PC. This happened immediately when I installed it and then got worse over time.
    The bubbles bugged me too much so I pulled the window to try again. HOLY COW!!!! What a job to get that window back out. I wound up de laminating some of the build up I put on the hatch to get the shape right. And I'll be cutting and fitting a new back window because I damage the original with the heat gun. Heat does nothing to soften the urethane adhesive.
    So I include a couple pictures for you to look at to remind you "Prep, Prep, Prep" before you paint!
