Results 1 to 38 of 38
Thread: Factory Five Customer Edward S. Finishes FFR Hot Rod #297
    Webmaster, FFR
    Middleboro, MA
    Factory Five customer Edward S. sent us an e-mail with photos of his almost finished Factory Five Hot Rod. Edward started the build with five other Hot Rods in his garage, all of them ’34s. He built the Factory Five ’33 with some modifications to make it look more like a the ’34s in his collection.
    Edward used a carbureted small block Ford mated to an AOD transmission from TCI, running through an 8.8″ Moser rear end with Factory Five’s 3-link rear-suspension.
    The wheels are 15″ x 8″ and 15″ x 10″ McLean Classic Hand Trued Wire wheels with 52-laced stainless steel spokes and powder coated rims and hubs. The tires are BF Goodrich T/A P225/60R15 in the front and BF Goodrich T/A P255/70R15 in the rear.
    Some of the mods Edward made to make the car look more like a ’34 included installing a custom 1934 cowl vent and louvered ’34 side panels, modifying the fenders and running boards to the ’34 style, and building custom frame extensions to support the front and rear Ford bumpers. He also installed the ’34 Ford chrome horns and custom glove box.
    Congratulations Edward on a fantastic build!
    Dave Lindsey
    FFR's Mad Dog
    Fresno, CA
    Great job with your build. Now I have more ideas to work with.
    Doug
    I love this car!!!! At first I thought it wasn't a FFR 33. Outstanding job Edward!
    I would like to see and know more about the custom cowl, engine panel louvers and the extensions he did for the bumpers. Is there a build thread anywhere we could check out?
    The bumper extensions could be a very good solution for those who have to have bumpers in their states.
    Very, very nice !!!! More pictures please !!!!!
    Senior Member Arm7419's Avatar
    Sedona Az
    Beautiful car
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    Can you share where the cowl lights came from ? Thanks.
    Hi Tim,
    The cowl lights are actually 1934 Ford aftermarket lights. They are available from any number of
    aftermarket suppliers. I purchased these from Dick Spadaro's Early Fords in Altamont, NY.
    Dick Spadaro 518-861-5367
    Quote Originally Posted by Vman7 View Post
    David I sent a rather lengthy response and lost it in the transmission someway.
    Quote Originally Posted by 154079 View Post
    My e-mail address took out for safety if you would like questions
    answered about the 1934 Ford modifications.
    Ed I sent a PM and an email
    Stillwater, NY
    I had posted some progress pictures for Ed a while back on the other forum:
    http://www.ffcars.com/forums/120-fac...upsate-ny.html
    Quote Originally Posted by Arrowhead View Post
    Thanks Arrowhead , don't know how I missed that.
    1934 ford
    Good morning David,
    George Robitaille, “arrowhead” posted some photos early on when I started the car and they
    will give you a glance into some of the modifications.
    The Cowl openings are simply cut out, saving the cutouts and using them as replacement lids.
    A ledge was added below the opening so the lids could be set in place and fastened down with
    S.S. fasteners. The larger openings are nice when attaching the Roadster Windshield. The engine
    side panels and inner fenders are all steel and were formed from flat sheet metal. They each have
    formed mating frames around them, the Hood Sides Panels can be installed or removed by simply
    raising the hood and lifting them out. The inner fender panels stay in place and are attached to the
    frame as well as the fenders. The Fenders are original 1934 Ford parts that have been modified to
    wrap down under the grill and extended to meet the Running Boards. The Hood and Fenders on a
    Factory Five Car are about 8 inches longer than the original 1934 Ford. The Running Boards are 34
    Original Steel that are also modified to conform to the Factory Five chassis and to meet the original
    Ford front fender lines. The cowl Vent is all original 1934 parts and the opening was fabricated.
    The Front and rear Bumpers are Original 1934 parts. I purchased 34 Front Frame Horns from a
    1934 chassis, made brackets that allowed them to be bolted to the Factory Five chassis and simply
    made the attachment. The rear bumpers were another project!! The entire rear portion of the car
    has been modified. The trunk lower panel was all modified including the latching mechanism and
    anything around it. The portion of the body below the trunk was extended 5.5 inches and bumper
    bracket mounts were formed into the fiberglass. A frame was constructed, added to the Factory
    Five chassis and bolted in place before the body was placed onto the car. From that point it was a
    matter of attaching the Bumpers and modifying the rear fenders to replicate the look of a 1934
    Ford from the rear view.
    I actually have seven 34 Fords including this Replica, they all have the original vintage appearance
    including spoke wheels, full fenders, a hood and a stance that looks like Henry Ford built the cars. My
    goal was to have the Factory Five closely resemble the cars I have with the lower stance. I’ve had fun
    with the project and feel I accomplished what I set out to do. I would admit that I have more time and
    money in this car than expected, but it’s cute! I have all kinds of pictures of this project so if you have
    a particular area that you are interested let me know and I will send those pictures.
    Ed Seagroatt
    Good timing Ed, I just logged on......
    Thanks for the great info on the mod.s!
    I figured you might have used 34 frame horns, was mostly wondering just how well they would work, and you pulled it off. The rear frame I gathered had to be some form of a subframe built, cool that you could just bolt it in.
    Pretty much everything you said, mostly about doing the bumpers/frame, and the side engine panels are pretty much the way I figured they would be done. Nice to know somebody actually did it.
    Thanks for all of the info on your vision on doing all that work.
    Ed was kind enough to send me some photos on some details for posting. Not sure in which order they were actually done, but I have tried to keep them in groups.
    Cowl Area
    Cowl Vent pattern to be cut out and re-formed
    Cowl Vent formed and placed in the car
    Cowl vent frame being bonded in place
    Cowl Vent and mechanism placement
    Cowl vent frame & mechanism brackets being bonded in place
    more of the Cowl Area
    Cowl Vent frame inside finished
    Cowl Vent frame outside finished
    Finished Cowl Vent
    Wiper system & Cowl Vent mechanism
    Dash Area
    Dash Gauge pattern
    Original 1934 Ford Glove Box
    Inside view of the Glove Box
    Fenders
    Front Fender Re-Construction
    Adding to the Front Fender to go around the grille
    Adding to the Fender Skirt to line with the Running Board
    Rear Fender Re-construction
    Rear Fender Tail construction
    Running Boards & Lower Rear Panel
    Rear Fender Running Board mating
    Front Fender Running Board mating
    Lower rear panel started to accommodate the Bumper installation
    Running Board Support Arms
    Engine Side Panels & Inner Fenders
    Engine Panel Pattern
    Louver stamped Engine panels
    Louvered Engine Side Panel cut to shape
    Mating Engine Side Panel and Inner Fender Panel Edges
    Inner Fender panel rear view
    more Engine Side Panels & Inner Fenders
    Engine Side Panel & Inner Fender installed
    Mating Engine Side Panel & Inner Fender
    Finished Cowl Vent & Engine Side Panel installed
    Front Frame Horns
    Front Frame Horn fabrication
    Front Frame Horns Installed
    Driver side Front Frame Horn & fender bracket
    Driver side Front Frame Horn installed
    Passenger side Front Frame Horn & fender Bracket installed
    Rear Bumper Frame
    Laying out Rear Bumper Frame
    Rear Bumper frame
    Rear Bumper Frame attachment points
    more Rear Bumper Frame
    Rear Bumper Frame temmporarily attached
    Rear Bumper Frame finished & installed
    Bumper temporarily attached
    Trunk Latch beginning modification
    E-Brake
    E-Brake Mounting Bracket
    E-Brake Brackets installed
    E-Brake and cable brackets
    Driveline Tunnel
    Driveline Tunnel being formed
    Driveline Tunnel finished
    Inside Door Details
    Door frame & hinge setup
    Modified Door Latch / Structure System
    Door Window Electric channel
    Electric Window Handle and Switch
    Enjoy all the pictures!
    Hopefully some of these pictures will help with those who need to have or just want bumpers or nerf bars. Some really good ideas here.
    Thanks Ed for sending the pictures
    wallace18's Avatar
    Trenton, Florida
    Wow! that was a lot of work. It sure came out nice.
    Extraordinary work on this beauty!! Wow, what a vision to make this all come together.
    Thanks for sharing the pictures on how you made it come together. What attention to detail. Stunning work!
    Fresno, CA
    Thanks David for posting all of the detailed photos. Now back to the garage with many new ideas!
    Doug
    Aliso Viejo, CA
    Amazing work. Truly. Hopefully Dave will have Dino shoot this car at some point. Really incredible.
    Calgary, Alberta
    Wow - what a great build! Nice work.
    Jul 2014
    Fantastic build. Thank you Ed for sharing yours and your teams efforts.
    Sedona Az
    Amazing. Just beautiful
    Chuck
    Chuck
    Hang Up and Drive
