I've always been concerned with the brakes on my 33. I did the disk and pad changes that were mentioned in a forum thread, with little improvement. Today I checked brake pressure at the calipers and only recorded 400 psi at each caliper. I believe this figure should be 900-1200 psi. Has anyone ever checked their brake pressure? To get a higher pressure I would need to change to a larger master cylinder. With the body on this is impossible on my car. Anyone have any thoughts on brake pressure and stopping performance on the Hotrod?
Chuck
