Results 1 to 23 of 23
Thread: Marv's 33 #465
    Senior Member Marv's Avatar
    Nov 2012
    Tucson, AZ
    Marv's 33 #465
    Received Thanksgiving day, plan is 306/345 HP Ford Racing engine, EFI (Mass Flow?) AOD, 3:55, A/C. Can't make up my mind on fenders/ fender less. To date front suspension powder coated and installed, firewall mounted, some wiring ran, pedal box in.
    Debating on, Boyd tank, what rear brakes to use, mounting brake reservoir on the firewall lots of options.
    Nov 2012
    Tucson, AZ
    Engine and trans installed. Ford 306 and a AOD.
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    Looking good Marv! Still waiting on FFR to finish mine, a few more weeks of agony until I can start.
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    Senior Member esff32's Avatar
    La Verne, Ca
    Looks great Marv. I bought that motor originally but ended up finding a 351W for a good price. That motor will be really nice once it's all built up.
    Nov 2012
    Tucson, AZ
    More on build
    Well I've been building on the weekends since the kit came. I have 45 miles on the car now, need to finish a lot of little stuff and then take it apart for paint. I think I'll finish fitting the hood this weekend.
    La Verne, Ca
    Marv, that thing looks sick. Very nicely put together. What color scheme are you going with? Cant wait to see it finished.
    Evan
    Aug 2011
    Midland, Texas
    esff32
    SLICK not sick
    Nov 2012
    Tucson, AZ
    Thinking Vintage Burgandy and maybe tan interior but may leave the interior black.
    Fort Lauderdale Fl.
    Very nice!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Nov 2012
    Tucson, AZ
    Sunroof
    Installed a soft top sunroof.
    Nov 2012
    Tucson, AZ
    So here's an update. The 33 is apart for paint. I have about 500 miles on it. I had to swap out the camshaft due to low vacuum to get the injection system working correctly. The new cam really performs better for the way I drive the car. I had the grill polished, put in the heat shielding and added Tim Whittakers hinge kit which by the way made a lot of difference. Here are a couple of shots. I can't wait to do final assembly.
    Nicely done Marv. Looks great !!!! Glad the door bushings worked out well for you.
    Tim
    La Verne, Ca
    Ditto on the door bushings Marv, very smooth operation. Thanks Tim!
    Senior Member rcotner's Avatar
    Wilsonville, OR
    Looks great! I am just getting ready to start on fitting door hinges etc. Tim, or Evan or Marv, how do the new bushings help? What is the benefit?
    Ray
    La Verne, Ca
    The bushings virtually eliminate the slop in the door hinges. The doors open and close very smoothly and there isn't excessive movement which could make aligning your doors a problem. The bushings need to be epoxied in the hinge arms and offset brackets prior to being installed but it is well worth it.
    Nov 2012
    Tucson, AZ
    Ready for Huntington Beach and some miles image.jpg I will post more pictures later
    Nov 2012
    Tucson, AZ
    Picture of 33
    Here is one
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    Looks awesome!!! Congrats!!!
    Fresno, CA
    That looks awesome. See you at the beach...less than two weeks away!
    Doug
    La Verne, Ca
    Beautiful car Marv, what size ragtop did you end up going with? Did you use www.slidingragtops.com?
    Nov 2012
    Tucson, AZ
    The sunroof is 40 by 30 from Sliding Tops. So it went to Huntington Beach and took Best Use of Chrome. It was a great time, got to talk with Dave Smith and a lot of Factory Five guys and gals. My friend from ZZZ Tops 33 took runner up best 33 HR
    La Verne, Ca
    I was there Marv and I was very impressed with your build. I had mine up Main street a bit on one of the side streets. Congrats on the award!
    Marv-
    Congratulations on the recognition, you certainly deserve it!
    I love the rag top. It gives you plenty of options, and I think you will really get some use out of it.
    Great color, and of course that chrome doesn't hurt either. Well done!
