Results 1 to 4 of 4
Thread: Headlight and twilight wiring on mark 4 roadster
    From Hughster2003:
    Can anyone tell me the wiring schematic for the plugs on the headlights and taillights. I have the five port plugs with six wires that do not match the wires from the harness. The entire car is done, except this, yikes! Later Hughster
    Senior Member DaleG's Avatar
    Mar 2013
    The Wiring Harness Manual has diagrams in it: http://www.factoryfive.com/wp-conten...ness-rev-L.pdf Not sure this will help, though.
    Actually, the build manual describes the wire colors/functions for the tail lights.
    Administrator G_Hodgkins's Avatar
    Dont you have a MK III?
    Dec 2012
    cuyahoga falls ohio
    No mark 4, and I just need the wiring code for the five wire plug so I can make the female to wire the headlight and turnsignals. I realize I can test each wire, but the wire code will make things easier..thank..Hugh
