This exhaust will come out right in the middle, right?
No cat, no muffler, good old style exhaust.
Yeap
That downpipe looks nice. I've never made an exhaust before and doubt it would look that clean if I did.
Zero Decibel Motorsports
Mechie, I weld and fabricate all day long so it has become second nature. You do great machine work, I really like your altinator bracket. They both require a high skill set, you could build one just fine. If you have any questions on welding etc pm me, the 20th can not come fast enough. I just got back from stripping another Rex since 3:30 am.
The correct offset wheels.. 17x8 40-45mm offset fronts with 215/40 rubber----- 38,40-45mm offest 17 x9-9.5 with 235-255/40 or 18x9-9.5 with 235-255/35 rears. You can run different stuff, but spacers and or other mods will have to be made. These sizes will work
255/40/18 rear? That fits without mods?
I thought the FFR recommended max size was 255/35/18.
255/35/18 rear, sorry my mistake, i will edit, but the 40 series might work as well with height adjustment etc.
