Hi guys, looking for info on motor mount brackets for LS3 2013 Camaro crate motor. Left side from C5 fits fine, passenger side not so much... Anyone run into this yet? Any help appreciated in advance
I couldn't get the new style motor mounts to work with my LS3 with Kooks headers. The rubber portion was nearly in contact with the header pipes. I ended up using the Pfadt mounts - much smaller, and more solid. Here's a link to my write-up.
http://rumrunnergtm.weebly.com/engine-mounts.html
I haven't updated my site in probably 2 years, but at least that section is accurate.
I also had to go with the older style C5 motor mount brackets. The newer version that came with my LS3 interfered with my AC compressor with it mounted low to the passenger side.
- Michael
Be sure you did not mount them backwards. If i remember correctly the way they look like they should fit , only works for one side. Flip them around. I am pretty sure I made that mistake using the c5 brackets on the LS3
XTF #2
build start date June 19 2023
GTM # 344
Build Start December 2010
First track day April 2013
The rubber mounts are very close to the Kooks pipes. I have the LS3/480 motor. Attached is what I did to help protect the mounts. They are made from Stainless Steel. .032 I think, easy to form. Hope that helps. DonHPIM0675 (1024x771).jpgHPIM0674 (1024x771).jpg
Finished the car mid March 2013. What a car!!!
