Thread: FYI LCA Mounting This is general. Perhaps relevant to all build threads.
    Houston
    My kit arrives next week, so I don't have any fitting knowledge yet!
    However my donor was an 06 with a left LCA damaged. I got a replacement which had a completely different bushing/mounting pivot. I don't know what vehicle it came from.
    The black one is my 06 part.
    Huntsville, Al
    That is an offset aftermarket bushing...I am using them on my car.
    Freeport, ME
    you need another original aluminum bushing, the other is not OEM
    Dan
    Houston
    Thanks....I have two of the (now) black ones. Are those the OEMs?
    Freeport, ME
    the aluminum colored one is OEM. I'm sure that you can adapt the aftermarket one...
    Dan
    Senior Member fateo66's Avatar
    Golden, Co
    The black one almost looks like an OEM one from a Forester that has been painted. Which looks to be what GT spec uses as there housing
    Forester
    GT SPEC
    Houston
    Thanks Guys....everyday I learn!
    fred
    That's very interesting. So if you didn't look at those together, it would be easy to miss the "offset". I wonder how much that would affect your steering geometry?
    WEK.
