Page 14 of 27 FirstFirst ... 4121314151624 ... LastLast
Results 521 to 560 of 1063
Thread: And it begins..."The Flash" Build Thread
  1. #521
    Huntsville, Al
    Lots of progress yesterday and today... Got pretty much ALL the front aluminum done...also completed the adjustment for the wheel and tire combination....
    So disclaimer.....
    Alignment is just quickly done and have not taken it out on the road yet....
    Seems like it will work out...
    Tire size is 235/40/18 ... this is about 1 inch more in diameter than spec.
    Initially it rubbed everywhere so stay to spec unless you want this look and a ton of work. I had to make/cut and rebend the outside front firewall aluminum, rear and front fender liners. I am also losing about 1/8 to 1/4 turn at full lock, but this is with the rough alignment. Looks like I could message it some more, but I am going to call it done....also the ride height is at 5" to keep the suspension at correct angle... this means I have to add .5 inches to the rear as well... anyway here ya go...pics!!
    stock panel on the left...mine on the right.. made the one tear drop slot go around the weld so it lay flat.
    All the front floors are in
    it's tight looking but it is a good 1/2 inch..
    got the wheel sitting in there nice and centered
  2. #522
    Exeter R.I
    Looking good bro, I am hitting with 235/45R17 as well, at this point I am going to get it to work
  3. #523
    Nov 2012
    Medina, OH
    Good info, thanks Erik. I was hoping 1" bigger diameter would work, just have to decide if its worth the extra effort for me. Most of the wheels I'm really drawn to only came in 18s or larger, but the rubber gets so thin at 18". I wanted a little extra rubber to have sOmE ride quality, it would be nice if my wife would like to come along for a drive. I'll be watching to hear reports from all the first builds on their ride quality with different wheel/tire combos. I'm not expecting Lexus traits, but don't want to donate a kidney either, lol.
  4. #524
    Aliso Viejo, CA
    Guys, I took all the tire pressure info and put it in the wheel and tire thread. It's a good discussion so if you want to continue talking about it, please do so over there. I hate to see Erik's build thread get derailed (again) . Thanks.
  5. #525
    Huntsville, Al
    So the HEAT is back in the south! ... kinda slowed things down a bit in the garage. But I got done what I had planned.
    Heat exchanger lines are now run from the back of the car to the front hat exchangers...I still have to hook up the driver's side, but that won't take but 20 minutes...
    Here is the exit point right before it hits the exchanger.
    so..like what took all day right....
    well I decided to hack up the stock wiper assy....
    and it works! .. ***disclaimer..this was the one and only time I ran the wiper dry and without it wrapped in a towel.
  6. #526
    Mechie3's Avatar
    Nice. I was wondering how easy a retrofit would be.
    Zero Decibel Motorsports
  7. #527
    Senior Member FFR-ADV's Avatar
    NH
    Very Nice Erik!
    Would you please share installation details and measurements for the single wiper installation? This looks great!
    Cheers!
  8. #528
    Awesome!
  9. #529
    FFR was working on the wiper install when I picked up my 818 last week. Should be available soon.
  10. #530
    Huntsville, Al
    yeah..i know.... but I am "mr. instant gratification"... and this was FREE....not including the labor...
  11. #531
    Hi Erik,
    Will the FFR version be much like yours? That is, are they using the OEM unit? Nice work. Thank you, WEK.
  12. #532
    Huntsville, Al
    Quote Originally Posted by skullandbones View Post
    Hi Erik,
    thanks..and I have no idea... my uneducated guess in no, their solution should be better.
  13. #533
    Senior Member AZPete's Avatar
    Thanks, Erik, for modifying the OE wiper. I hadn't seen anything about an 818 wiper so I was hoping the OE wiper assembly I received from AJW might be useful. Now I know it's possible and that one blade sweeps the windshield. Thanks!
  14. #534
    Senior Member gwader's Avatar
    Torrance
    Very nice!
  15. #535
    Huntsville, Al
    Well happy sad today.....got the axles put together a went for a drive....3rd gear synchro is all done..pops out of third...throw out bearing pulled out of pressure plate and appears to be broken (nasioc.com bought used)... the VF52 turbo takes a LONG time to come into boost!.... anyway other than that....drives nice...still needs an alignment, but everything checks out fine...tranny is under warranty through Subaru and VeryCoolParts.com will hook me up with a new clutch...in the time being, I will throw my stock turbo back in to see if in fact the turbo is the issue...hope so...
    here ya go...
  16. #536
    Mechie3's Avatar
    To be honest, ive been slightly concerned i will end up in a similar spot of finding out something doesnt quit work after being in a wreck and then sitting for over a year. Fun to finally get a drive though!
  17. #537
    Huntsville, Al
    It all can be fixed!
  18. #538
    Exeter R.I
    Very cool Erik, everything will work out
  19. #539
    Denver, CO
    What do you consider long time to boost? That vf52 should be pretty good buildup. Search on legacygt.com for the dyno charts of it.
  20. #540
    Huntsville, Al
    5 psi a 3500, 11 psi at 5000 RPM...boost controller set to max boost.
  21. #541
    Mark Dougherty's Avatar
    Hershey PA
    well done eric
    way to stick with it.
    The traveling Builder
    717-773-5624
  22. #542
    Nice drive but very long build up on the turbo, yes!
    Is your WG dumping to atmosphere?
  23. #543
    Huntsville, Al
    Thanks guys... Well the only other thing I need to check is that all 4 holes are firing... Compression was fine but my coils and connectors are a question mark... So maybe another issue... Sure feels low on power everywhere... Guess we'll see
  24. #544
    Senior Member fateo66's Avatar
    Golden, Co
    That sounds extremely slow, but then again if you were only loging in first gear that could be right. Expect the values in 3rd gear to drop significantly. Also do you have the boost restrictor pill in the small 2" long boost line coming out of the turbo's compressor housing? Thats often a really easy part to over look.
    1997 RSVX Impreza Awesomeness!
    1999 RHD 22B RSTI
    2002 WRX
    2005 Saabaru
    2008 STI
    2013 FFR 818 #30
  25. #545
    Erik, are you dumping your WG to the atmosphere or through the exhaust?
  26. #546
    Aliso Viejo, CA
    Congrats man!
  27. #547
    Huntsville, Al
    Well... Turns out... 2 bad coils! Might explain a few things!
  28. #548
    Huntsville, Al
    Well since I can't do any burn outs on 2 cylinders.... the body work can start...
    so in my quest for a nice clean yet functional look.....since the front has hinges....how about the back....
    open please....
    have to add the latches tomorrow and makes the gaps perfect!
  29. #549
    Exeter R.I
    Very cool man!!!!
  30. #550
    Senior Member metros's Avatar
    NoVA
    I like how that works. Pretty cool set up.
  31. #551
    This guy is GOOD!
  32. #552
    Huntsville, Al
    ok...now I reversed the hood pins at the b-pillar and will make an access point inside the car to pull the pins when I what to open the rear hood.
    finished up making the rear hood all one piece...ready for primer!
  33. #553
    Denver, CO
    Oh Erik...where is Erik? I am dying for updates.
  34. #554
    Huntsville, Al
    Car still isn't firing on all 4 holes yet.....sent ECU off for evaluation...I think I may have cooked it in my rush to get things started...
    in the mean time....updates....well I bought another pack of this....
  35. #555
    Huntsville, Al
    Ok so a "little" more info....
    some detail work
    I wet down one of the door panels....looks pretty smooth to me
    Sanded down to 320
  36. #556
    Like your mod to the rear panels. That will look great when you are showing off the engine bay and very functional too. Great work! WEK.
  37. #557
    Exeter R.I
    looks good bro,,, wicked pissa lol,,,,inside joke now, I am about to drive it soon, and I am looking at some body work soon
  38. #558
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks great, love your color choice.
  39. #559
    Denver, CO
    Sorry to hear about the ECU problems. Hope it gets fixed soon. car looks great though.
  40. #560
    Torrance
    Looking good!
