Results 1 to 6 of 6
Thread: Undercoating
    Senior Member esff32's Avatar
    La Verne, Ca
    Undercoating
    I was wondering if you guys could share what brand/type of undercoating you used on your panels. I was going to spray it on the underside of my floors before I rivet them down. I'm curious as to which ones have worked the best. Thanks for the help guys.
    Evan
    Aliso Viejo, CA
    If it's just for coating Evercoat makes a nice easy spray you can get which provides a textured, paintable surface that doesn't smell like tar as much as the Pep boys stuff does. For heat resistance, lizard skin is the way to go. Personally, I'd run the heat shields and undercoat as well as the sound mat inside. With your HP, it might get a bit hot underneath.
    I didn't even undercoat my aluminum. I just used it for the inside of the body and it all worked just fine.
    I had great sucess with Lizard skin. Check my thread you will see what I did. It is good to see you back at it!
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    My plan is undercoat and use heatsheild. I hope the spray adhesive holds the heatsheild, sure be embarrassing going down the road dragging a a piece. Also have the mat for the interior. After running my car a bit this week I can tell the underside has got to get pretty warm.
    La Verne, Ca
    Thanks guys, i think i will fabricate a couple of heat shields to along with it. I gotta get my arse in gear Wallace, you're on car number 2 and got yours after i did. Sometimes life gets in the way. Haha
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    Quote Originally Posted by esff32 View Post
    I hear ya!
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
