Results 1 to 16 of 16
Thread: Belt tensioner avail for no air conditioning or power steering???
    Freeport, ME
    So I have little Subaru knowledge:
    (I do have a bunch of big piles of 2005 WRX donor parts tho!)
    I want to run my 818 as a more basic ride, no power steering or air conditioning, simple to delete the two pumps, use a single shorter belt... but what about a tensioner? Am I going to have to fabricate one? The existing ones don't look like they will work...
    Dan
    FFRs prototype 818 already is in configuration.
    Freeport, ME
    That doesn't really answer my question...
    Looking at the WRX motor the belt tensioners seem to be sort of integrated into the pumps, so when they are removed, the belt doesn't have a tensioner for the alternator. Is there a subaru tensioner available or do I need to modify one of the existing ones to be an alternator belt tensioner?
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    AC belt is separate from the PS/Alt belt. So no problem there.
    The bracket that the PS Pump sits in is what the alternator uses to give tension to the belt. It's the alternator that provides the tension. Deleting the PS would provide no problem measuring for and getting tension to just a belt for the Alternator
    PS pulley on left (larger). Alt pulley on right (smaller). Crank pulley behind hose.
    Different angle of the above.
    Close up of ps bracket with ps pump still in it.
    PS bracket without PS pump
    Mechie3's Avatar
    Indianapolis
    Just cut down the ps bracket to a minimum and reinstall it to mount the alternator and tension it.
    Zero Decibel Motorsports
    Check out my new website!
    Freeport, ME
    Thanks for the great photos... w/o tearing them apart it looked like that tensioner was part of the device vs a complex aluminum bracket... It looks like it can be chopped and cleaned up nicely!
    GS guy
    Guest
    Trimmed my alt. bracket down and used an Outfront mount for the pivot side. This got rid of the massively heavy AC mount.
    Jul 2012
    Quote Originally Posted by GS guy View Post
    Nice work GS, how about a picture of the pivot side.
    Freeport, ME
    very nice, exactly what came to mind!
    GS guy
    Guest
    Here's the Outfront Alt. bracket. Works good, but cheap plating - getting some pinhole corrosion spots despite never having seen any real weather exposure. I may just have it refinished with powder coat.
    Jul 2012
    London
    I butchered the cast mountings in a similar way. Belts are easy to get hold of, measure with a piece of string then order from local motor fators
    Senior Member Oppenheimer's Avatar
    Milford, CT
    OK, so in another thread you used the phrase 'break the car', which I know translates in Amercan to 'part out the car'. I also know chips are fries, crisps are chips, bonnet is a hood, boot is a trunk, lorry is a truck, bobby is a cop, randy is horny, but uh, what are 'Motor Fators'?
    Jul 2012
    Definition for motor factors:
    Web definitions:
    A supplier of car parts and accessories.
    en.wiktionary.org/wiki/motor_factors
    In other words, and autoparts store.
    Jul 2012
    London
    Quote Originally Posted by Oppenheimer View Post
    Sorry, the "c" and the "i" keys are missing from the laptop keyboard, and sometimes don't work, adding to the confusion, must get another one at some point.
    Junior Member randy808's Avatar
    Colorado Springs, CO
    Do you have a link for the belt you used after removing the ps pump? And sorry for the newbie question, my motor didn't come with belts :-)
    Freeport, ME
    belt comes with the kit... now I have an extra!
    Dan
