Results 1 to 11 of 11
Thread: Stiffening (Strengthening) Trunk Floor Suggestions
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    I've been cruising around this site for ideas. Any suggestions on how one might strengthen the trunk floor at the bottom tier. Would like to be able to carry a case of beer or something heavier down there than a feather pillow with some sense of security.
    Thoughts?
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    I have one here now that I thought about doubling the floor with another piece of aluminum. That or put some small aluminum angle pieces riveted to the underside of the trunk floor. You can buy angle 1/8 thick as small as 1/2 inch.
    Thanks Mike, on thought i had was to work on the inside and see if i could get a hat channel maybe 3/8 high. make 3 rows from front to back and build up floor possible use 1/2 mdf on top side and insulate between for noise.
    FFCars - lowntubd
    Aug 2013
    Lee's Summit, Mo. (Kansas City area)
    Add some coremat, and another layer of fiberglass, and it will support your car. Simple fix. Be sure to strip of any finish, and rough it up with 36 grit abrasive first.
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    I plan to add one of Eric Hansen's trailer hitches to my build. Strengthens the trunk floor (since I am planning to put my battery in the trunk) AND allows me to buy one of those cool matching trailers...
    ERIC
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Quote Originally Posted by Robert Andrew View Post
    Maybe dumb question but will coremat adhere to aluminum? Then should i used a fibreglass mat product or a cloth as top layer?
    FFCars - lowntubd
    Milton,DE
    I made a new floor out of .050" aluminum. It really made a difference.
    Olli
    N E PA
    I built a sub-frame out of 1" sq tube. It supports the trunk and supports the rear of the car. PM me if you want any more info or pics.
    Ted
    Thanks roadster. Looking at mine I cant see me having enough room for rear exhaust, but excellent idea.
    FFCars - lowntubd
    Aug 2013
    No, that was a very logical question. You can now tell that I haven't received my 33 yet, and I made an assumption that the trunk floor was fiberglass, rather than aluminum. In that case, you had better follow the lead from one of the other guys, and make a new truck floor out of thicker material. Sorry if I caused you any wasted time and motion.
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    After playing with trunk floor and latch assembly I agree the floor could use some extra strength. Looks like some aluminum angle stock will work fine for my application.
