Looks great Marc. Can't wait to see it all come together.
It's never too early to start beefing up your obituary.
Car looks great Marc. I still like the blue and white paint scheme a lot. When I see these cars painted it has me re thinking my paint scheme.
Thanks guys...I am pretty excited at this point. Working around other obligations to get this done so progress is a little slow.
The car looks great in many colour schemes. I took the easy way out by picking Guardsman Blue. Sometimes I think I should have tried something different.
It's just A Matter Of Time
Marc
FFR Coupe 434, 347ci, Power Brakes, SAI Mod, 3 link rear
Fluge
You done right by her in Gaurdsman Blue. I had the same problem agonizing over what color to choose and went with Gaurdsman Blue. Now everytime I'm out in the shop putting the coupe back together I look at the color and am so glad I went with it especially when I roll -er- drive the coupe out in the sunlight and that color just glows..
Bill
Coupe #421, Picked Up 11/15/08, started 1/1/09 - Rebuilt mildly massaged 302, T5, 3 Link, and Loads of Extras
Hey Marc...you are really rolling along...great progress and it looks great...another vote for Guardsman Blue...
If it's too LOUD....you're too OLD!!
Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
FFR#0441CP Complete Coupe kit, IRS, T-5, 392ci 351W, Webers, Delivered 4/29/09
Thanks Chris and Bill
No regrets...Body looks great. Doing the headliner today and the body goes on for the last time on the weekend.
I'll put up some pictures then.
Marc
Marc
Marc
car looks great!
Factory Five Type-65 Coupe:"Race Spec" coupe, Ordered 1/12, picked-up 5/12, roller 5/12, first start 10/12, finished 4/13
Factory Five Roadster: Sold 12/2011.
http://www.25tires.com
Marc,
That looks like a color picture out of Carrols garage! looks awesome.
Fluge
I used Steele Rubber Products Part #83-0139-73 for the glass hatch weather strip. I used the longer rubber side to the inside. This seal is taller than the FFR supplied seal. The peel n stick is on the side rather than on the bottom. Worked great on mine. With glass hatch closed the seal left a slight rubber edge all around the glass. I tested the seal with a piece of card stock slid in under the glass all around the perimeter and it wouldn't slip all the way through so the seal should be tight. They sell it in 10' lengths at $36.10 each plus shipping at $10.75. You'll need 2 lengths. Might be able to use the rest someplace else. I've sealed the doors with FFR seal but can't figure what to use at the front seam. Stuck there for the moment.
Bill
Thanks Bill. It looks like it would work well.
Marc
Marc
Marc
It looks great!
Great looking car.
Wow! That is a beautiful car!!
Marc,
You are building a great coupe ... and almost done. Looks wonderful ... I am jealous!
Thanks for the kind words guys (and Julie). This has been quite the journey so far. I am very pleased with what I have been able to do.
Marc
You should be proud. You've done a beautiful job building it.
Marc
Really looking good. Looks to me like you could drive it now...who needs windows????
Marc,
Your list is getting shorter!! There's many things on this car you can't see in the pictures.
Marc
Absolutely gorgeous!!! It also looks like you have a shop to die for!!! Tell me about how you fastened the rear upper splash panels to the nose. I'm at that stage right now. Matter of fact made the first pattern of the left side upper rear. I'm making the pattern in three pieces and taping the pieces together and tracing them on aluminum. The FFR pieces were too small in height. I thought of some "L" shaped brackets glued or fiberglassed to the nose with a slight loop to clear the push on seal.
Bill
Hi Bill
Thanks for the comments.
The upper splash guard or wheel well was installed exactly how you describe it. I epoxied aluminum tabs bent at 90 degrees (using 2 bends to offset it enough to make room for the rubber bulb seal). I drilled holes in the base of the tab so that the epoxy would be pushed through to add strength. Because my under hood is also finished for paint we covered to base of the tab with HSRF to smooth it out. I used three tabs on each side (driver and passenger).
I did have to trim the aluminum a little but otherwise I got them to fit well.
I recently saw another thread discussing this issue. There were some pictures showing the tabs glassed in. The two pieces took a lot of fiddling and an extra set of hands would have been great.
Hope this helps.
As for my garage...thanks, it has come a long way from what I started with.
Marc
Marc
I'm still working on a few things but a spring graduation is definitely in the air.
I dropped off my wheels for powdercoating today. There is still a fair amount to do but it will be driveable by the time the road salt get's washed away. I hate the thought of covering up the interior aluminum. I like the look as it sits but I could use a layer of sound deadening.
Marc
Marc
Fluge -
Tell me about your lift - I am considering one of those for my small 2-car garage - thanks.
Your Coupe is looking awesome - thanks for posting pictures and captions - it helps us who are still in the build stages......
-wayne-
Ordered Type 65 Complete Kit Aug 29, 2012 - The 50-50 $ale!
Standard Width IRS; Halibrands - 17x9, 17x10.5
Kit Arrived: Oct 9, 2012; Build Started: Oct 28, 2012
WordPress: http://wayne-yoshida-kh6wz.com/
LinkedIn: www.linkedin.com/in/waynetyoshida
YouTube: http://www.youtube.com/user/kh6wz?feature=results_main
Hi Wayne
The lift you see there is a rotary lift. I bought it 10 years ago. Great lift with no issues. I use the 110v motor is and takes about 1 minute to go all the way up. Going up and down requires your full attention and the slower 110v gives you more reaction time if something isn't right. It has a ladder frame brake system which I really like. I think the lift is one of the best things I ever did. I made reinforced steel trays on which I can put bottle jacks to get the car up on floor jacks. Takes me less than 10 minutes to do that. You can get lifts with very different dimensions so it's really what you can fit into your garage. I recommend bolting down the posts once you are sure where you want it. Try it unbolted for a few weeks and make final adjustments before bolting it down. I also bolted the ramps down on the runways so that they wouldn't tilt when the lift is up. This allows me to drive the SUV under the lift. This lift has seen a lot of up and down action. I have another lift which is lighter duty and is used for car storage only.
Not sure what else you want to know...happy to address specifics.
Marc
Marc
I just finished reading this thread for the first time. What happened to the pictures and what happened to the finish? It just abruptly ends in March.
Hey Marc, You're a slacker!!! LOL. Only 2,000 miles?? Put mine on the road 6/27/2014 and have accumulated 6,300 miles. Last road drive was 12/05/2014 until snow hit us. Actually could have driven it this Friday the 19th due to temps in the high 30's (heater works good), but I was sick. There have been a couple of rains so no salt on the road. I think it probably is in the garage for the duration now.
By the way I love that rookie stripe on front, wish I had thought of it. I also noticed the alternator and AC compressor positions are swapped from what mine are. What brackets did you use?
Bill
Hi Bill
I decided to use the March pulley kit. I did have to switch to an electric fuel pump but it does clean up the engine bay.
I have been tempted to take it out of hibernation a few times myself. I still have a few things to finish up on it but been too busy...maybe once the Christmas rush is over.
Marc
Marc
Marc,
On the hood I see you put the little bumpers back in. When I visited you only had the weather stripping in place because the bumpers did not support the hood properly.
Where you not happy with the result of only the weather stripping?
Hi John
It comes down to tweaking the fit. The bulb seal isn't thick enough in some areas so I built it up with the bumpers. I may try replacing what I have with a thicker seal.
Marc
Marc
thanks for the final pix. You've built a beautiful car and must be real proud. Any chance of getting the earlier pix back on here?
I thought about this too, so I checked out his photobucket and found http://s561.photobucket.com/user/DDO...?sort=2&page=1
Of course you don't know which pictures go with which posts, but it is still great stuff!
