Results 1 to 40 of 46
Thread: aluminum lower control arm question
    According to FFRs assembly manual these were only on the 2006 wagon. I need ball joints for mine but the parts store units are all the same regardless of year or wagon\sedan. Do the cones come separate from the ball joint? If so where do I get them?
    Thanks Mike
    wallace18's Avatar
    Trenton, Florida
    I replaced all my balljoints, tierod ends & wheel bearings on my donor parts. I got them from Rockauto. Fast service and good price.
    Freeport, ME
    aluminum arms were on STIs and 06 WRX
    the steel cones should be fine...
    Dan
    rori's Avatar
    Tulsa, OK
    They came on 2006 WRX SEDAN only and STI's. Ball joints are all the same though and yes the cones are separate. Probably dealer only.
    QC, Canada
    I thought 2007s also got them?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Nope.
    Nov 2012
    Medina, OH
    Lol, I did too until I found my2007 donor had steel. Oh well, steel it is
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    The little steel cones are dealer only, ask me how I know...
    Anyone have a part number?
    Mechie3's Avatar
    Indianapolis
    Car Vin: JF1GD79616G521625
    Part Description or if you have a P/N: Boss Transverse Link, 20216Fa000
    I just ordered two from the dealer. They were going to give them to person A at an autocross and Person A was going to deliver to me. Person A says person B has it, person B says I didn't know I was supposed to get these so I never got them, the dealer rep says person B. So....I'm out of these too.
    Sad part? I had them but think I accidentally dropped them in the scrap metal box and recycled them. Doh!
    Zero Decibel Motorsports
    Check out my new website!
    nkw8181's Avatar
    Dallas, TX
    So are the aluminum lowers the same from the 06 wagon and the sti? the Donor I'm looking at will most likely need the left front lower replaced. When I look on ebay some say sti and others just say wrx.
    Nolan
    Eugene, OR, USA
    Quote Originally Posted by nkw8181 View Post
    Nolan
    Nope. As rori stated:
    Quote Originally Posted by rori View Post
    They came on 2006 WRX SEDAN only and STI's...
    '06 SEDAN only has aluminum lower control arms. The wagon had steel lower control arms...
    nkw8181's Avatar
    Dallas, TX
    OK I thought it was the other way around lol.
    Nolan
    Aug 2012
    Long Island
    but the SPT ones were always available.
    SPT ? ? ?
    Aftermarket supplier?
    Aug 2012
    Long Island
    Subaru Performance Technology... factory performance parts. They've always had them and you can get them from the dealer or online.
    I paid $310 for mine and they include new stiffer bushings and ball joints. A no brainer, don't buy junkyard ones with dried out bushings and have to get new ball joints.
    part number is: B2010FE251DS
    Senior Member Turboguy's Avatar
    Canada
    Is that $310 a pair or each? And is that a discounted price over "list" ? If you have a sec, please shoot me a PM with where you got yours. I will just go there for mine.
    Clovis, Ca
    That's for the pair. I bought a set for my R. It really is a "No Brainer".
    Thanks- Chad
    Ditto for me on the PM please.
    Eugene, OR, USA
    Me too? If that's not asking too much...
    Edmonton, Alberta
    Are their any other advantages to getting the aluminum ones besides weight? And what is the weight difference?
    Eugene, OR, USA
    Weight actually isn't much of an advantage. Mostly it's looks. There is also the greater likelihood the alum ones will be the fail point in an accident rather than transferring energy to the frame.
    EDIT: Not sure what the actual weight difference is. In the discussion below, I realized I got the steel & alum LCAs backwards in terms of strength - the alum one is stronger and therefore has a higher probability of transferring crash energy to the frame.
    EDIT 2: The weight difference is apparently 2 pounds.
    Freeport, ME
    Quote Originally Posted by Xusia View Post
    Steel 7 lbs, AL 2lbs less @ 5 lbs (OOPS, typo)
    and the aluminum ones are stronger, & more likely to damage the frame... :-)
    Dan
    Eugene, OR, USA
    Are you sure? I was under a diff impression...
    Freeport, ME
    yes, discussed with Subaru nuts when I was shopping for a donor, the forged aluminum arms are much stronger... My 05 roll over had a crunched left front LCA. The steel LCA splits apart on impact where the folded metal is tacked together to form the control arm. The aluminum arm is much stiffer, giving better suspension control and providing more force to the unibody if impacted.
    Dan
    nkw8181's Avatar
    Dallas, TX
    Lighter isn't always weaker. All about the design :-)
    Nolan
    Aug 2012
    Long Island
    I don't think they weigh 2 lbs. feels much heavier. sent pms. the site's not going to know what hit it.
    Eugene, OR, USA
    Post updated.
    Freeport, ME
    OOPs, typo, the AL arms are 5 lbs, 2lbs less... sorry
    Dan
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I've been doing some reading on front lower control arms and it seems that there are several different aluminum control arms.
    The part number given above, B2010FE251DS, is for a complete set of right and left control arms for a WRX that are nearly the same as the ones that come on an STI. At $310-350 a set they are a pretty good deal if you desire them.
    However, the arms that actually come on an STI are part numbers 20202FE900 and 20202FE910. One of those is left and the other right. These arms supposedly provide 1.5 degrees of additional caster over the other ones. They are a bit more expensive at about $225 each, so a bit more money.
    If I understand it correctly, and I may not, the actual STI parts would move lower ball joint forward a small amount. Seems like this might provide a bit more clearance at the back of the tire.
    Can anyone confirm my information and logic?
    Larry
    Aug 2013
    Santa Rosa CA
    I have also read that the STI has more caster built into the control arm. I don't know how it will affect the tire clearance to the frame bit it will change on the front of the front fender. The 818 has an abundance of caster and camber adjustment , unlike the donor. However 1.5 degrees is not very much. I think any clearance change would be minimal.
    Quote Originally Posted by D Clary View Post
    No so minimal
    Tangent of 1.5 degrees X (ball joint to top of strut distance= estimate 24") = 5/8" forward at ball joint.
    Aug 2013
    The sti castor adding lca adds castor by moving the lower ball joint forward. When I set them side by side it looks about an inch.
    nkw8181's Avatar
    Dallas, TX
    Well dangit and there I though if was just the bolt spacing at the top and its thickness. Does the hub offset to account for the difference in the lower arm or will the wheel turn sit forward 5/8-1in?
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    It might not be a big difference, but if it gives enough clearance to use a 215/45-17 instead of a 215/40-17 it opens up the choices to quite a few more tires.
    Larry
    Aug 2013
    The front 04 sti knuckles are the same as wrx, just different hub choices. 05-07 sti knuckles have different mounting on top, which after seeing zachs upper arm, I believe ffr accounted for this. Also the geometry of the 05-07 is the same as wrx, they just used the lca to add caster.
    Also, regarding lcas, if your going to use the quicker sti steering rack you will want the extra caster. Makes for a scary highway experiance if you dont have enough caster.
    Eugene, OR, USA
    Look what came yesterday!
    Aug 2013
    Non caster adding I see.
    Eugene, OR, USA
    If I determine I need more caster, there are lots of ways to handle that.
    QC, Canada
    Do they come with the bushings? Those small parts at the bottom of the pic, the ones people always install backwards due to the flat bend and curved bend?
    Do you have to use the ones from the donor or FFR provides some? Still talking about the bushings, the control arms themselves.
